Joco1114
Alt+F4
Thu Aug 19, 2010 8:01 am
Interesting experience:
I have an HTPC with a remote controller. I can use all functionality of Splash Pro with remote: Play, Pause, FForward, Backward, Info, Full Screen, etc. But sometimes (not always) the Alt+F4 (Close) function is not working. I tried to press on keyboard, on the remote, but not working. I have to click on the screen (playing area of Splash Pro) and the function will working again, I can close the player.
It seems the SPro "forget" this hotkey while playing a long file. With other player has no similar problem.
Can anyone confirm this problem?
Home Theater:
Synology NAS 1010+ | 9TB HDD
Joco1114
Re: Alt+F4
Tue Aug 31, 2010 5:27 am
Still waiting for the confirmation... I realized, the problem appears only in full screen mode. Full screen + AltF4 = not always working.
Home Theater:
Helios
Re: Alt+F4
Wed Sep 01, 2010 8:02 am
Hi Joco1114,
unfortunately I can not confirm the issue.
The only scenario I found when Alt+F4 doesn't work in full screen is when I change the focused window with Alt+Tab but still see the fullscreen video. Then I press Alt+F4 and it seems nothing happens, but other window closed in fact.
Are you sure there is no other task in your system (eg. anti vir) that could pop up a window with some message, but you dont see it because you have full screen video? In this case you may be focused on other window than splash.
regards,
Joco1114
Re: Alt+F4
Wed Sep 01, 2010 1:17 pm
Other keys are working, for example if I switch off the fullscreen mode, I CAN use Alt+F4. No other program to steal the focus.
Home Theater:
user82
PC Specification: Q6600,Ati HD-4850
Re: Alt+F4
Wed Sep 01, 2010 9:33 pm
Helios wrote: The only scenario I found when Alt+F4 doesn't work in full screen is when I change the focused window with Alt+Tab but still see the fullscreen video.
A Problem I mentioned Months ago in Splash free ;)
Joco1114
Re: Alt+F4
Tue Sep 07, 2010 11:04 am
Alt+F4 problem is exists in v1.2. I have to restore the previous state from full screen, then I can close it.
Home Theater:
