Action! does not open after reboot
Posted: Thu Aug 30, 2018 1:55 pm
by Arnold Luiz
The first time you install the action on the computer normally opens however after shutting down the computer or rebooting, you click on the action icon and the loading screen appears normally but after loading nothing else happens.
Re: Action! does not open after reboot
Posted: Fri Aug 31, 2018 6:58 am
by Piotr
Please download this zip:
http://master.mirillis.com/action_dbg.zip
and unpack it to Action! installation directory, then run Action! and provide us with Action! txt. A log file (action_log.txt) from the startup process will be created in your User/AppData/Local/Mirillis folder.
We need this file to exactly see where the problem occurred.
